Cant access phone number after transfer
AndyLA
Hi @CS_Agent After porting from Rogers to Public Mobile, during the e-sim process it messed up and now i dont have access to my original number. And i cannot sign into my account due to the text message verification. I was hoping i can sign in and transfer to a physical sim.
Kmoiseevs
I’m in the same boat! It’s been 36 hours and I’m so frustrated. I submitted multiple tickets, private messaged customer support and used the chat feature multiple times. I reset the network settings, restarted my phone, and played around with carrier settings on my phone. Nothing helped. I’m so upset no one got back to me in more than a day. Can’t login into my account because it sends a verification text to my cell and I don’t have access to incoming texts. Ugh! Let me know how quickly you get to resolve your issue. Tried calling Telus (parent company) tonight but they are closed!
@AndyLA
There are no CS_Agent on this public community forum. We are all members like you.
hi @AndyLA
maybe you can fix it quickly
Check Settings -> Cellular and check if Public Mobile eSIM is there.  Make sure Turn on this line is enabled and set as Primary .  Then try Reset Network Settings
if same, message support and ask.  You can  submit by direct message:
@AndyLA  You need support to switch to physical sim at this point and help with transfer
send  a  private message   To CS_Agent
