06-08-2023 09:15 PM - last edited on 06-08-2023 09:19 PM by computergeek541
I am not sure if this is a sim card or phone issue.
Can anyone help because I have zero clue what it means.
Thank you
06-08-2023 09:25 PM
@MermaidMolly Make sure your power and volume buttons are not broken. Turn the phone off and quickly press those buttons to make sure they are not stuck. Then power it on again and see how it goes.
06-08-2023 09:23 PM - edited 06-08-2023 09:30 PM
Hold down the power button and power off then power the phone back on…I think it just need to be rebooted.
Ultimately, you might have to bring it into a cell phone repair store to have it checked.
06-08-2023 09:23 PM
@MermaidMolly it is a phone issue., not sim
You can also test your PM sim in another phone to confirm.
06-08-2023 09:21 PM
Samsung A5 I've been with public mobile for 5 years
06-08-2023 09:17 PM - edited 06-08-2023 09:19 PM
What is the make and model of phone? Can help if we know what type of phone it is.
The phone could be locked by another carrier.
06-08-2023 09:16 PM - edited 06-08-2023 09:17 PM
@MermaidMolly , that looks like a possible phone issue. It does not appear to be booting up properly.
