Cannot receive incoming calls but can make outgoing calls, said number not in use when others dial m
kpotseung
PAULRANG18
The port has likely not been completed and could take a few hours or even a day. Contact a moderator if issue persists by clicking ?, bottom right, and follow instructions to submit a ticket. Moderator wait should be a few hours or within a day.
@ChuckYeah wrote:
@kpotseung I wonder if this could be a situation where they gave the same number to two clients. Try calling the NEW number from your own phone and see what you get.
Sorry, I just noticed you chose the number on August 20, I'd contact @CS_Agent .
If you NEED a moderator, create a support ticket:
Explain your issue to SIMON, seen below:simon.PNG
Use as few words as possible to allow the BOT to understand (e.g. no service, can't send texts, can't call out or no data) Answer Simon's questions until you get here:
Spoiler
@CS_Agent will respond to your concern through the community's private messaging system, usually within 48 hours.
Watch for this indicator of a private message, probably from a moderator.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours: Monday-Friday: 8AM- 12AM EST; Saturday & Sunday: 8AM-10PM EST
geopublic
@kpotseung
Edit: Best to submit a ticket to PM.
kpotseung
No, it is a new number I activated on 20 Aug 2019.
Jb456
Did you recently port your number from another provider?
