Cannot make out going calls
Brianajones
I can sent and receive text from  a number, they can call me, put when I call them get a 6UC2 error number is not in service
ZestyCheese
I've been having the same problem since yesterday.  8UV1 call cannot be completed as dialed.
Brianajones
Thanks
Phone is working now, shut off for 10 minutes and when restarted everything is fine
There have been issue since Wednesday for some people with both incoming and outgoing calls.  PM is aware of the situation and working on a solutoin.
You can try to change to 3G only and see if it connects to the network at all with such settings
If that does not help, I suggest you to open a ticket with PM support and let them aware you are one of those, too.  Some customers got the ticket to support and got it resolved quickly
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
