Cannot input MMSC or MMS Proxy - iphone 6s
Dave13
I have an iphone 6s and the access point network page only allows me to enter the apn and not the MMSC or MMS Proxy.  The page is blank other than the apn.
mimmo
@Dave13  I find this thread the ultimate guide for all iOS questions
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323118#M24562
Also make sure you have the latest Carrer updates installed.
You can “type” into the APN settings.
popping
@Dave13
After network reset and these 2 fields are not set.
Create a support ticket to ask moderator to send you the provider file to update your APN using this link https://publicmobile.ca.ada.support/chat/
But it will be at least one day wait to get a moderator.
LurganIeUk
SE is same as 6s. This is all you can do. This works for me. Others may use isp.mb.com
gpixel
@Dave13 hi leave the APN settings alone and reset your network settings
1. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
