Cancel order
Shawnabond
How do I cancel an order
HI @ThatPug   not bad to return after if it is a CPO phone.  OP can try it out first  🙂
ThatPug
They're sadly swamped at the moment to the point that it'll take 24-48 hours to cancel an order, so yeah just returning it is the most likely solution if it's a phone.
Meow
What kind of order?
PM service or add-on - cannot do that once paid
Ordered phone - you have 30 days to return it. You could contact agent and inquire if it is shipped or not and then discuss with agent cancellation.
HI@Shawnabond
For addon? for sim card or phone?
For sim card, likely no refund , no cancellation
For phone, you can do that, they have a 30 days full refund anyway
For add-on, they might be able to put the money back in your My Account.  If you have bought that by mistake, and  you didn't use the add-on at all, it should be ok
Just open ticket with CS agent for your enquiry:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
