Canada wide calling
westbridge25
I have the $25/month plan, which is suppose to include Canada wide calling. But when I called Calgary, the call wouldn't go through.
7 REPLIES 7
Yes nothing wrong with adding a 1 (and the area code too) in front of numbers you dial or save in a directory. I'm Assuming there are still some places left with 7 digit dialling but you can dial all 10 digits even if a local call. But just put 1 and area code in your directory and you're good to go.
AE_Collector
Loki1025
I always add the +1 to the beginng of any number in my contact list when saving new contacts.
totalUser
I just saw another post about this, 1 in front woud do the job
Welcome to public mobile:)
kselmak
If you are dialing correctly, just ignore the warning message that it's long distance number, it still connect after. If it annoys you next time dial 1 in front.
dabr
Try adding +1 in front of the numbers you are calling.
gblackma
@westbridge25 try dialling a 1 in front of the numbet
totalUser
Check the number again, when that happens too me it's usually misdial
Does it say it may be long distance?you can ignore that message
If you can reach that number from a different phone ( fongo or textnow) then contact moderators https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
