Canada - Us Promotion
Rga211
Do I need to purchase a US Roaming add on if I have the new Canada-Us Promotion for 39.00
Rga211
Ok Thanks
DennyCrane
Nope, it's part of the core plan. On your phone check the following settings:
1) Turn on Data Roaming
2) Set Preferred Network to 4G/LTE vs 5G
3) Set Network Selection to Automatic. If this doesn't work, manually connect to T-Mobile or AT&T.
For phone calls to work you need to ensure you have a VoLTE capable phone per PM's list:
https://www.publicmobile.ca/en/on/get-help/articles/volte
@Rga211
no, you don't.  The US roaming is included in this Canada-US Plan.  You will just need to connect to T-Mobile or AT&T and turn on mobile data roaming on your phone
