Canada -US $34 plan applicable for Ontario New members?
Bunty2
The Subject sums up the first question and how can i install e sim the first time around?
Cannonman631
Did you see 75 gig Canada USA plan you won't loose your rewards
@Bunty2
eSIM, pick that when you activate, and remember to use the PM app to activate, not the browser
At the end of the Activation process, the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, support can help at that time
@Bunty2 create account on the on the app and you will have  option to choose eSIM and install it to the phone and yes the 50GB $34 CAN/US plan is available in Ontario . Seems everyone in the country can create new account with this plan
