Can't send/receive picture message?
mdeze215
Hello,
I can't seem to send or receive picture messages. My plan is unlimited messages so I know it's covered and I have compared my APN settings as was mentioned in one of the other posts. Still no luck. My wifi and data are both on and functional. Any ideas? I'm on android btw.
Thanks
2 REPLIES 2
mdeze215
It was affected!! That did it. Thanks
@mdeze215 what brand and model your phone??
Not sure if your phone is affected by this announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
if you are using a device that released after 2017, generally, you can simply click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or        default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
