Can't send or receive pictures in sms
free7reigns
What settings to get pictures or send pictures..I get txt messages.Is there a setting to change??Or is it public mobile data not working correctly
free7reigns
I fixed it thnx
It was a setting in apn thnx
free7reigns
Umidigi g1max
B4 u answer or anyone else there are settings in the phone.Anyone thinking it's plug and play I had to make adjustments to make data and phone wrk
Can you otherwise browse the internet not on wifi?
APN Settings:
If you're able to edit then use the following. If adding then let me know.
Check your apn settings, particularly the apn type:
Name: whatever you want
APN: sp.mb.com
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
APN type: default,mms,dun
APN enable/disable: APN enabled - probably on anyway and greyed out
MVNO type: GID
MVNO value: 4D
Save, then select to use, then go in and out of airplane mode
free7reigns
Umidigi g1max
Data is on
I assume it's with public mobile
This phone should work if it sends and receive txt..only pictures it does not work
Oi hope public is not blocking data
dust2dust
Sending pictures is actually MMS which then requires cell data turned on to send and receive. What make and model phone?
