Can't send email to text
Juku1
Hi,
I can no longer send email to text via phone#@msg.tellus.com or phone@mms.mb.telus.com. Whatever I sent (from my computer), my iphone did not receive it. It has always received it before.
Any idea?
Thank you,
JA
24 REPLIES 24
HI @vbelina
this is an old features and will probably go away.  Rogers already retired the email to text last year.  It is a matter of time Telus to cut that
vbelina
Hello... the one I am using is @Msg.telus.com ... the other two, are not working... it looks, my email-to-text functionality was BLOCKED by Telus... and there is no one from there to tell me why... this makes me think... 😞
vbelina
Thanks Oracle...
- will try with the other TWO for SMS... and report later how it worked out...
@vbelina
try all these domains, start with the SMS's.  if you try MMS, make sure mobile data is turned on
SMS Domain:
  @msg.telusmobility.com
@msg.telus.com
@msg.koodomobile.com
MMS Domain:
@mms.mb.telus.com
@mms.koodomobile.com
@mms.telusmobility.com
vbelina
Hi... same here... for the last few weeks my phone@msg.telus.com is receiving email-to-text DELAYED by TELUS servers by a couple of days... "Gmail will try for 46 more hours... mobilEpUb.1964"... DELIVERY INCOMPLETE...
The response from the remote server was... "421 4.2.0 mMB1riz8VxF2SmMB1reqm1 mail accepted for delivery AUP#BL" ... This is happening for the last few weeks now... only the TELUS IT could fix this, but... are they ever read these cries for help ? ... so what's the solution, getting ready to migrate?
Juku1
I sent between 20 to 30 test messages.
@Juku1 wrote:
The usage showed me 3 incoming SMS messages (2 from 999-9999 yesterday and 1 from 2200 today which is the test message I sent some time today and just received)
@Juku1  how many you tried email to text today? you found any of those there you in the log?
I tested using  @msg.telus.com  and it shows and entry from 1 (999) 999-9999  .  Not sure if other MMS domain will have the same from phone number
Juku1
@Juku1 wrote:
I clicked on the link then and it opened a blank page but the page is still spinning now. Not sure what's the problem is.
@Juku1 that is the link to Usage history
you can first Login  My Account, then click Usage history from the link on the overview page (or then use this link
 https://myaccount.publicmobile.ca/en/account/plan/usage-details  )
Once you are there, see if you see any entry like this
Incoming SMS            1 Message                     1 (999) 999-9999
Juku1
I did not have cell data on then but I just tried it now with data on. No difference.
MMS was on. I just turned it off now then tried again, same problem.
Juku1
Subject line makes it an MMS. Did you turn on cell data? Or is your phone set to automatically receive MMS?
@Juku1  i see +19999999999 with the text email to sms I got . that's the FROM phone number of that text
@Juku1
go to My Account, usage history ( https://myaccount.publicmobile.ca/en/account/plan/usage-details  ) and see if you see any entry like this
Juku1
Thanks but not possible because yesterday I did receive (albeit only) two texts from my email, at 30 minutes apart even though I sent them one after another.
BTW, where do you see 19999999999? On the two texts I received yesterday, they showed the email where I'm sending it from, followed by the subject line and then the body text.
Juku1
Wish I can say the same. It's driving me nut.
I have no problem with getting sms from any other source. The problem seemed to start yesterday when I only received two texts from my email, at 30 minutes apart even though I sent them one after another. Now I don't receive any.
@Juku1
i tested it again with @msg.telus.com and  it works
are you receiving other sms without problem?
honest , i doubt this email to text is a feature not really supported by PM, so not sure if open ticket with support with help
dust2dust
Have you possibly blocked +19999999999.
Juku1
Thanks.
I didn't have iMessage on. Rebooted my phone but no luck.
Juku1
Thanks, but it didn't work.
Juku1
Thanks, but no luck.
@Juku1
try all these:
MMS Domain:
@mms.mb.telus.com
SMS Domain:
@msg.telus.com
@Juku1  .maybe try rebooting your phone or reset network settings and see if that helps
Chalupa_Batman
So the issue may be you have iMessage only as an option. I just tried it from my email to text and it worked just fine. Check your settings and see how you have messages set up. You may need to reboot your phone.
