12-30-2023 07:16 PM
Any inbound calls go straight to voicemail. I've recently signed up, and transferred my number from Rogers. I confirmed the transfer with the Rogers SMS. I've also waited 6+ business hours since initiating the transfer.
I can't submit a support ticket, as I get a 404 from the chatbot link.
01-03-2024 12:18 PM
Thanks all! All sorted now. Cheers
12-30-2023 07:30 PM
hi @johalloran check if your Rogers sim still functioning. If not, it's good, Rogers passed the number to PM already. What you need to do next is to reboot the phone and test both inbound and outbound calls
if outbound calls so not work, the sim was not setup properly on the system, please submit a ticket with CS Agent here:
12-30-2023 07:17 PM - edited 12-30-2023 07:32 PM
@johalloran No worries I’ll send you the porting team number private message , call them they can re trigger the port request for you
12-30-2023 07:17 PM
Hi @johalloran
Seems like the port didn't go through right. I'll PM you a number to call to fix this. Check the top right corner of the page.
