Can't receive calls and send text messages.
nepalivcg
Hello,
I bought a new sim card and activated my sim on Sep 10. However, I am having the below issues. I saw a few similar posts, but the solutions involve private messaging the moderator. I have messaged the moderator but haven’t received a response yet. Any of your help would be appreciated.
- I haven't been able to receive calls, the calls don't go to voicemail either.
- I have also not been able to send text messages.
- I was not able to receive verification code (text) from Uber either.
Thank you.
nepalivcg
Thanks @Jarvar
A moderator replied to me and the problem was solved after changing my phone #.
Jarvar
@nepalivcg
Hereis a thread on the APN settings for ipones. Take a read through it as it also has some members talking about other issues with iphones and how they solved them. Hopefully a moderator gets back to you soon if it is a deeper issue that requires their intervention.
http://productioncommunity.publicmobile.ca/t5/Announcements/iPhone-Update-and-APN-settings/m-p/1610#...
nepalivcg
@Jarvar
Thanks, it’s an iPhone 6s. I did not port an existing number, it’s a new one.
I have the $35 plan with data.
nepalivcg
@will13am, I did not port a number, it’s a new number.
Jarvar
@nepalivcg
Welcome to Public Mobile. It must be difficult when signing up for a new service abd everything is not working as expected.
That was a good call messaging a moderator and getting things started.
Could you provide some more information?
What kind of phone do you have?
Did you also port a numbet over to Public Mobile or did you sign up for a new one?
Which Public Mobile plan do you have? Do you also have data?
This extra information would help in finding a solution.
will13am
@nepalivcg, did you attempt to port a number?  Usually the inability to receive means failed port.  You are in the right track to seek moderator team assistance.  Their response time is around 48 hours.
