08-12-2023 11:31 PM
Hello ,
I recently switched from a physical Sim card to an eSIM, and I thought it was done correctly, but for some reason I can’t receive phone calls, but I can make them . SMS messages seem to be working fine thou
what do I do ?
08-13-2023 12:45 AM
Have you tried 'Reset Network Settings' in your devices settings App?
Is the old deactivated SIM Card still in your device?
08-12-2023 11:37 PM
try cycling Airplane mode ON then OFF...see if that helps.
08-12-2023 11:35 PM - edited 08-12-2023 11:46 PM
@Steve1983 wrote:Hello ,
what do I do ?
@Steve1983 , have you rebooted your phone yet & removed your Sim Card from your phone? This is what I did after I received confirmation on my iPhone’s screen that the eSIM successfully installed. I also reset my iPhone’s network settings as an extra measure.
Edit: Once mine was installed I received an email telling me that I switched from a SIM Card to an eSIM!
08-12-2023 11:34 PM
@Steve1983 Try and Reboot the phone first . Or then try reset network settings . If no luck please submit ticket with support to help you
private message To CS_Agents click
VVVVV Link below VVVVV
