10-29-2021 11:39 AM - edited 01-06-2022 03:54 AM
My phone just stopped sending or receiving calls, text works
11-06-2021 10:08 AM
I bought a new sim and that solved the problem
11-01-2021 03:38 AM
Rest your carrier settings
10-29-2021 01:07 PM
@Golfernow wrote:My phone just stopped sending or receiving calls, text works
If you are on $15 plan maybe you ran out of minutes? But you should be able to receive calls.
What your Account says? Still active with plenty of minutes?
10-29-2021 01:00 PM - edited 10-29-2021 01:03 PM
If you can try swapping the SIM card with another phone and your card won't work with the other phone but the SIM from the other phone works normally in your phone, I would open a ticket with CS to have it checked:
If the SIM can't be fixed, you'll need to buy another one. Keep the receipt to ask for a credit to your account.
Edit: If a good SIM won't work in your phone, then it would be a phone problem. Check all the settings, do a network reset. Maybe even a factory reset as last resort.
10-29-2021 12:20 PM
When did this happen? I wonder if you ran out of minutes - you can log into Self Serve and check your plan details online. Note that Public Mobile renews your plan every 30 days and not monthly like most other providers. This means that the plan renewal date shifts from month to month so your minutes/etc also won't renew the same time every month. Other options to reboot, call 611, and 3G are all good things to try as well.
If you're able to send and receive texts, there is no need to reseat your SIM card. Your SIM and phone are logged onto your account if incoming and outgoing text messages are working.
10-29-2021 11:55 AM - edited 10-29-2021 11:56 AM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
This is quick and simple,
10-29-2021 11:44 AM
@Golfernow reboot your phone first.
If issue persists, try to change the Network to 3G Only
Still fail, try to go to a different area (in case there is an outage where you are at) or try your SIM in another phone
And.. does your Mobile Data work?
10-29-2021 11:41 AM - edited 10-29-2021 11:46 AM
Dial 611 from your cell to get a status update on your current plan. Have you run outta minutes on a plan ?
edit; if you have a plan with limited calling and have run outta minutes, you can get the $5 / 500 minutes of Canada wide calling add-on.
Alternatively, you could upgrade to $25 plan with Unlimited Canada wide calling.
10-29-2021 11:40 AM - edited 10-29-2021 11:49 AM
Which plan do you have ?
Trying rebooting your phone. If you have another phone then try swapping the sim. If you still have problems then try a network reset.
