07-10-2023 03:08 PM
Hi There, I'm messaging on behalf of my daughter. Her Public plan expired and she is trying to make payment but its asking for a 4 digit code sent to her number. She cant access the code because her plan is expired. Please Help!
07-10-2023 06:18 PM
@Pirate1966 happy that it is sorted
07-10-2023 06:14 PM
Update: Email option worked. My daughter is up and running she thanks everyone. Great team work here 🙂
07-10-2023 03:58 PM
Thankyou everyone for your help. Will try the email option to have the code sent too.
07-10-2023 03:27 PM
@Pirate1966 @Tap resend a few times and you should get option to send code to email instead .but if all else fails please
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
07-10-2023 03:21 PM
HI @Pirate1966
try "Resend code" and see if the option Send email is there
if the option to email is not available, you will have to submit ticket with CS agent and ask them to help
Or you can also buy vouchers from Shoppers Drug Mart and load voucher to resume the service first
07-10-2023 03:17 PM
do you know the 4 digits account pin for used on the phone? If so, call *611 or 1.855.4PUBLIC from another phone and make payment that way
if you don't know the account PIN, then you need to find a way to get back into My Account
PM just changed to a new EverSafe login system and you need to complete the setup on this new system.
Have you login to My Account since EverSafe was introduced?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
