Can't get into my self serve account because I'm locked out of the email.
ew1
when i sign in i cant because im locked out of the email i used to sign up with. and i want to change the email
2 REPLIES 2
Yummy
Contact agent to reset your access and change your email
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
@ew1  - to change the email connected to your My Account, submit a ticket to CSA to have them change it for you.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
