Can't call in or out.
AAAGlobal
My text msg works and data works but I can't call in to my phone number goes to VM. I can't call out either from my handset. It just started last night no number port, active account. Ive had this number for a while now.
@AAAGlobal
To the network settings on my ZTE Axon 7
  1. Scroll to and touch Settings.
  2. Scroll to and touch Backup & reset.
  3. Touch Network settings reset.
  4. Touch RESET SETTINGS.
  5. Touch RESET SETTINGS.
  6. The network settings have been reset.
AAAGlobal
I'd like a network reset, I don't have another phone to test the some. I'm running Android 9 via lineage os on an axon 7. It's an old phone but I just replaced the battery and I'm getting lte connection I'm typing this message over data now. If the sim was the issue I would imagine that I wouldn't receive or send txt msg or have data. Tried restarting the phone and pulling the sim and reinstall.
BeachNBeer
What kind of phone do you have? Is software fully up to date?
gblackma
@AAAGlobal Try switching your sim into another phone to see if if its the phone or a SIM problem. Stay safe.
Triguy
Try rebooting your phone.  You could try making your phone lost then wait 5 minutes and mark it found. If it is still not working then try a network reset.
