Can't call after I transferred my number
Alicia8
I'm not able to make any calls after I transferred my phone number from Freedom to Public Mobile. Everything is working fine except I can't call anyone.
Can I get help on this?
11 REPLIES 11
@Alicia8
likely tomorrow morning, but the sometimes reply late at night too, so monitory your community inbox.  Message them again if you don't hear anything at noon
@Alicia8  not till tomorrow now most likely hours 9am-10pm EST but
Alicia8
I sent them a message. When will they reply?
Alicia8
I tried the above and I'm still not able to make any calls.
I'm using an eSIM card from Public Mobile.
My old SIM is from Freedom and they have deactivated my account.
I clicked on the link to open a ticket with support and the link didn't work.
Alicia8
My old SIM is from Freedom and they disconnected my account.
I believe I took out my old SIM card too quickly.
@Alicia8 wrote:
I'm using a e PM SIM card and yes I can't make any calls.
It can receive calls but it says No Caller ID for incoming calls. My data works.
@Alicia8
try what I suggested above
Also, try your sim in another phone if possible
and open ticket with support if that does not help
@Alicia8  Can you try the SIM card in another phone to test
Alicia8
Alicia8
I rebooted the phone. Incoming calls work.
@Alicia8
your PM sim card cannot make calls?
can it receive calls?  does data work?
try to reseat the sim card with a reboot.  Power off the phone first, then take the sim card out for a minute, put it back and power up
Also, click Reset All networks and see if it helps
You can also test by changing the network mode to 3G only
if issue persists, please open ticket with PM support and ask them to reprovision the sim/account:
@Alicia8  Have you rebooted the phone or tried reset network settings ? Do incomming call work ?
