Can't call US and login issues.
moondin
Hi.  I can't call US, although my plan says I can. Says call cannot be completed.
Then when I try to create a ticket, asks login info, i put it in and never accepts it.  I also don't get any reset password.
but click signin above and i login. So frustrating.
Can someone pm me why I can't call and what's up with my login?  are there two passwords, one for community one for main site?
7 REPLIES 7
@moondin wrote:
okay it was the number. Weird. It's a famous restaurant and didn't say out of service or anything. Just a weird code error.
@moondin
glad it is resolved.
The error code could be from the provider of the number of that restaurant instead of PM
Yes, I notice couple restaurants I like to go in US have closed down since pandemic  😞    I guess, always check Google first
moondin
Community site is so weird.  It says "welcome moondin" but sign in link above.  Can't send ticket cuz it won't let me sign in, verify also never enables verify button.  Please fix this.
but working now.  thank you.
@moondin wrote:
it's $50/month.
it says on website:
Minutes Usage:
Unlimited talk to US
@moondin   Good, you have one of those older $50 offered before July 13.
Did you try to reboot your phone?
also, try different US number and see if it works.
.. and what area code you are calling and failed?
moondin
it's $50/month.
it says on website:
Minutes Usage:
moondin
i can't even verify, so many website issues.  I can't believe a professional company like this runs such a horrible website.  Been at this 30 mins just trying to send a ticket.
Meow
You must be on some old, grandfathered Plan as none of current Plans have US calling as feature. To call US with current Plans you would need add-on.
If creating ticket does not work, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
@moondin Which plan do you have that include the US calling?  Please note only some of the plans included US calling minutes
You can try to reboot the phone and see if it works
Also, which US area code are you calling?
For login issue, if you want to open a ticket to reset the password, please use one of the two methods below:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
