11-29-2023 05:29 AM
No matter what I try, I can't seem to activate the eSim on my iPhone 13 mini. Followed the steps in this other post, https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-activate-esim/td-p/1018081 but none of those steps seem to work. The phone just says Unable to Activate Sim over and over again. I am connected to wifi and normal websites seem to load ok. I may need some assistance figuring this out
11-29-2023 10:13 PM
For anyone else with this issue. I hadn't heard back from customer support, so I ended up buying a physical Public Mobile sim at a Telus store and updating the SIM number in the profile section of the portal. Not sure why the eSIM didn't provision properly in the first place. Also a word of caution: if you provisioned through the PM app and your phone says unable to activate SIM after a while, do not delete the faulty esim record. It's burn-once and will not be able to be used again if you remove the line from your phone (for example, to attempt to use the QR code instead). You'd have to pay for a new eSIM in this case unless customer service takes mercy on you
11-29-2023 06:10 AM
Did you get to the eSIM installation step or did the eSIM installed? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
