09-04-2018 11:19 AM - edited 01-05-2022 01:39 AM
I cannot send or recieve texts (though shows in messages as being sent) or use data.
Can't make or receive calls, message says I do not have a long distance add on.
Added payment voucher today and online account shows plan is active.
Message center # in Text settings is correct.
09-04-2018 03:12 PM
If future you can buy vouchers online at recharge.com. as to your issues why sending images works which uses data and nothing else..
09-04-2018 02:48 PM
Its a Samsung. Checked all network settings and everything looks good. Nothing blocked, changed, enabled or disabled.
Phone worked Sunday, no service Monday due to holiday and no payment vouchers ANYWHERE in my city except Walmart.
Applied voucher this a.m and nothing works on the phone except sending pictures.
09-04-2018 12:32 PM
@AGD wrote:Thanks, just sent them a message.
I tried everything from rebooting to manually changing the message center phone #, everything on Account looks to be okay as well.
For some reason I am able to send picture messages but nothing else.
If you have an iPhone, you may have enabled iMessage.
09-04-2018 11:55 AM
09-04-2018 11:50 AM
@AGD, it is possible that you have have experienced a renewal bug in your account although that was supposed to have been addressed. Try rebooting your phone to see if that helps. If not, I suggest reaching out to the moderator team for assistance. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code. Refer to the following knowledge base link for additional information on contacting the moderator team.
