Can not Make Calls
mohammad-shamas
Hi,
I can not make calls. I can receive them but can not even call my voicemail or any one in my contacts. I tried moving the sim to another phone but it is the same problem, please help.
8 REPLIES 8
maple_leaf
Hi @mohammad-shamas , have you checked your subscription status in your online account, or have you called *611 from your phone? If still having trouble, you can reach out to a Customer Support Agent for further assistance.
Private Message a CS_Agent:
Monday to Sunday 9 AM to 10 PM EST
Hope this helps.
Community_QA_
tried reset all network?
or try the sim in another phone?
try 3G?
mohammad-shamas
Yes I do
@mohammad-shamas Are you putting a 1 in front of the contact
mohammad-shamas
No, I have been with public mobile since 2017
mohammad-shamas
no error message. just beeps and call failing. No I am not on a plan with specific amount of minutes.
Do you hear any type of error messgae when trying to make outgoing calls?  Also, are you on a $15 plan that includes a limited amount of outgoing minutes?
HALIMACS
@mohammad-shamas
Have you recently activated here and porting your number from another provider?
Did you reply "yes" to the port authorization request?
