12-05-2023
01:16 PM
12-05-2023
06:53 PM
computergeek541
Can I still receive calls from the U.S. after I run out of Talk minutes?
12-05-2023 06:54 PM
12-05-2023 01:26 PM
@Gwanzi wrote:yes you can, Just need to be careful not to make outgoing calls
If you run outta regular plan minutes, you simply won't be able to call out. Outgoing calls just won't complete until next regular renewal or you get a calling add-on ($5 / 500 minutes of Canada wide calling) You'll never be billed for calls at a later date.
12-05-2023 01:25 PM
Yes, you can. Your minutes limit is regarding OUTGOING minutes only. And no extra charge for receiving calls.
12-05-2023 01:23 PM
12-05-2023 01:22 PM
BTW...if you are on a plan with limited calling minutes such as the $15 plan...good idea to consider either upgrading to $25 plan OR buy a $5 add-on with 500 minutes of Canada wide calling. Those add-on minutes don't expire but stay on your account until you use 'em up...even if that takes several months or years. It's a good addition to your $15 plan.
12-05-2023 01:19 PM - edited 12-05-2023 01:20 PM
In coming calls should not be affected no
12-05-2023 01:18 PM - edited 12-05-2023 01:19 PM
Yes @jinnrers
Incoming calls from anywhere are always included in your plan.
The $15 plan includes 100 outgoing minutes so you can run out of those.
12-05-2023 01:18 PM
@jinnrers Yes all incoming calls are free no matter where they come from US or mars 🙂
12-05-2023 01:18 PM
yep...incoming calls are unlimited as long as your current plan is Active.
