08-19-2022 10:44 AM
Our plan did not include USA calling. About an hour ago I purchased US calling and texting (10 day package for $20.00). Now when I try to call, I get a message that there is no available minutes. Any idea why I still can't call the US?
08-19-2022 11:05 AM
In the meantime, you could buy the 1000 minute and make those calls and then the support people can just credit your account back and remove the roaming add-on.
08-19-2022 11:01 AM
Thanks. I have contacted a CS Agent to see if the plan can be switched.
08-19-2022 10:56 AM
You bought incorrect add on. You bought US add-on to be used FROM the USA. You need 1000 US minutes to call USA.
08-19-2022 10:50 AM
You need the 1000 minute add-on. You bought roaming. That's for when you're in the states. Contact the support people to switch it around.
