08-07-2018 03:00 PM - edited 01-04-2022 06:40 PM
I am interest about the $10 plan, 50mins canada wide talk, is the call forwarding is free (no need to addon) and unlimted forward minutes? or it will use the 50mins from the plan if i forward the call?
Thanks
Felix
08-07-2018 06:31 PM
@dacatz unused plan minutes do NOT roll forward to the next 30 days. Unused long distance add-on minutes [if you purchase any] remain on your account until they are all consumed.
08-07-2018 06:24 PM
Thx for the reply, does the mins accumulates to next month? What happen if i didn't use up all the mins? Let say I have 25mins left this month and do I get 25mins +50mins for up coming month? Or it will reset to only 50mins per month?
Thx
08-07-2018 03:07 PM - edited 08-07-2018 04:36 PM
The call forward minutes will use your 50 minutes from your $10 plan.
You can purchase $8 200 minutes add-on which does not have expiry until fully used.
16 cents per minute for the $8 50/50 plan
4 cents per minute for the 200 minutes add-on
