Call can not be completed as dialed.
Samantha8
Incoming calls are ringing but as soon as I accept it hangs up, and I can't call out. Why?
2 REPLIES 2
HI @Samantha8
Please reboot the phone once and try Reset All Networks
And you can try to change the network mode to 3G and it might help
and if problem just starts today and it was good before, maybe just network problem today.
If you joined and it never work well, can we know what phone do you have?
@Samantha8  Try resetting network settings , also can you try the sim ard in another phone to test ? . Also check .
Outage map in your area:
https://istheservicedowncanada.com/
If still no luck submit ticket with support
send a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
