11-23-2022 11:27 AM
Hi all. I'm trying to prove that I called someone about six months ago. Without phone records it's he-said she-said. Is there any way to get access to this info? I found some old forum posts that said you could but it seems that maybe the feature has been removed.
11-23-2022 11:47 AM
PM provides only 90 days of usage history.
You can ask agent if they have access to longer period.
But your phone should keep all call history, correct? I can see calls made/received back to Sep 2020.
11-23-2022 11:31 AM
HI @phonemonkey
No, you can only get up to 90 days of usage record
of course, you can try to open ticket with CS agent, but I highly doubt they will help
just in case you want to try , to open ticket
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
