06-05-2020 02:22 PM - edited 01-05-2022 11:02 AM
My plan allows for 1GB of data per month.
My phone is showing that I have used 2.2MB of that.
But today I received a text from Public Mobile saying I have used 75% of my data for the month. What does all this mean? My "month" starts on the 8th of each month and today is June 5.
06-05-2020 02:47 PM
Thanks everyone. My phone was indeed showing only the usage from June 1. Problem solved.
06-05-2020 02:43 PM
@Fantuz Check your self-service account please. It always shows correct data amount. Maybe your new cycle didn't start yet, and the message belongs to the old cycle. Maybe, message was sent by mistake.
06-05-2020 02:30 PM - edited 06-05-2020 02:31 PM
@Fantuz public's plans are only 30 days, your renewal date changes. don't rely on your phones counter, it is never correct. mine is off by 1gb even when setting the correct usage cycle reset date.
06-05-2020 02:30 PM - edited 06-05-2020 02:32 PM
@Fantuz wrote:My plan allows for 1GB of data per month.
@Fantuz PM plans renews every 30 days and your phone maybe showing whats been used this month and it looks like you're almost near your renewal time so you probably have almost exhausted your plan data. You can purchase the $15/1GB data-on for now, this will be used once you've depleted your plan data before renewal and any remaining data from the add-on will stay with your account until completely used up.
06-05-2020 02:29 PM
Billing cycle is on a 30 day period.
You can view your usage in your Self-Serve account by clicking on the Plan and Add-Ons tab, then on Data & Add-On Usage. Here, you will find a summary of your data usage for the current billing cycle. Alternatively, if you’re interested in seeing your your last 90 days worth of usage, you can select Usage History which is also under the Plans and Add-Ons tab.
06-05-2020 02:25 PM - edited 06-05-2020 02:31 PM
PM plans are 30 days not monthly.
Log into your self serve account. Look at My Data and Add-ons. It will show you how much data you have used so far. You can also see when your plan renewal date is once logged in.
