12-23-2023 11:08 PM
Can any tell me if I can use my business credit card to pre-authorized my bill?? I currently unable to do so. Thank you
12-23-2023 11:23 PM
@hTideGnow wrote:you just need to make sure the name on card, card number, CVV, postal code registered with the cards are correct
The above isn't correct. Public Mobile does not check, nor does it ask for the name/business name linked to the credit card.
12-23-2023 11:11 PM
HI @captaincool
technical yes, PM does not care if it is personal or business credit card
Try to wait an hour and then use Incognito/private/secret mode on your browser to login My Account and try again
