02-14-2022 12:14 PM
my unlocked phone is not listed in the compatibility list. Before I sign up I would like to know if my current phone is compatible on your network. its a Blackview BL6000 Pro.
02-14-2022 12:58 PM
02-14-2022 12:30 PM
That would be a YES as it would be compatible just about anywhere according to this list.
02-14-2022 12:24 PM - edited 02-14-2022 12:25 PM
Also confirmed from Backview
https://store.blackview.hk/products/blackview-bl6000-pro-5g-rugged-smartphone
(the highlighted one are the matching frequency)
3G | WCDMA: B1/2/4/5/6/8/19 TDS: B34/39 CDMA: BC0/BC1/BC10 |
4G | FDD: B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28A/28B/66 TDD: B34/38/39/40/41 |
02-14-2022 12:20 PM - edited 02-14-2022 12:21 PM
This phone is compatible with the Public Mobile services based on the information from these sites.
https://en.wikipedia.org/wiki/Telus_Mobility
https://www.devicespecifications.com/en/model/81e554e0
02-14-2022 12:20 PM - edited 02-14-2022 12:20 PM
Yes, it should work:
FYI,
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
HSPA: 850 MHz, 1900 MHz (UMTS).
4G = B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
3G = B2(1900) B5 (850)
