2 weeks ago - last edited 2 weeks ago
2 weeks ago
self solution removed
2 weeks ago
Also would recommend removing the image of the one with your debit info on it even if it's only the last 4 numbers
2 weeks ago
you're right I thought I was opening a suport ticket thanks for the heads up
2 weeks ago
You are going to need to put in a ticket to pm. This is a public forum. Use the chat bot to make a ticket
