12-30-2020 02:01 PM - edited 01-06-2022 01:41 AM
12-30-2020 02:07 PM
To update or remove your credit or Visa debit card details, sign in to Self-Serve. Once signed in, click on the ‘Payment’ tab, then scroll to the bottom of the page and select ‘Manage my card’. Here, you will have the option to either select ‘Replace this card’, where you can enter the details for your new card, or ‘Remove this card’. You will need to review and confirm this change to your account and then you’re all set..
12-30-2020 02:05 PM
@Rodeugene , you can go into your self serve account and remove autopay from the payment tab. If you are really concerned, you can also remove the payment card.
12-30-2020 02:05 PM
@Rodeugene wrote:How can I stop autopay
Login to your self-serve account.
Go to payment page and select Manage AutoPay link to remove AutoPay.
12-30-2020 02:04 PM - edited 12-30-2020 02:05 PM
Log in to your self serve and toggle it off.
Dial 611 and using your 4 digit PIN, toggle it off.
Edit: But why? It's a free 2 bucks.
