2 weeks ago
Hello! I know there are lots of threads to discuss this topic. However, I still have no idea which way will work. I am currently in the US. Would like to use my US credit card to subscribe a plan. However, the zip code field only accepts Canadian zip code format.
Can anyone kindly provide some instructions about how to use US credit card for the pre-activation/registration process?
E.g. Use US VISA to purchase a Canada prepaid VISA? Where can I purchase such Canada prepaid VISA online? etc.
It's quite urgent. Any help is highly appreciated. Thank you!
2 weeks ago
Got the update from the CSA, for monthly subscription, the only acceptable payment for pre-activation is to use Canadian Credit/Debit card. Prepaid credit card or voucher will NOT work.
2 weeks ago
Hi! Thanks! I have asked a friend to purchase a Vanilla Prepaid VISA Card for me. However, it is NOT working. I got the error message.
2 weeks ago
Thank you so much! I guess any prepaid credit card will work? I heard Vanilla Prepaid Credit card is a good choice? Thank you!
2 weeks ago - last edited 2 weeks ago
HI @bestofluck
yes, preapid credit can can be used for activation.
I tihnk the minimum is $25 or so on those card, but there is a initial fees when you buy prepaid cc
2 weeks ago
Hi! Thank you so much for the reply! Do you have any idea if any Canada prepaid credit card will work? I am also wondering if there is a minimum balance requirement for the prepaid credit card?
Thanks again for the help!
2 weeks ago
HI @bestofluck
yes, zip code is an issue. While US issued card can be used, but it has to tie with a Canadian address. Prepaid credit card is the only workaround, can anyone help to get you one? I am ot sure if you can get prepaid credit card online.
