Anyone else having issues applying referral codes?
tiffk17
Is anyone else having issues with applying referral codes?
I've been in touch with 3 reps, all whom have told me that mine would come through eventually. However, it's been 6 days, and the $10 credit still isn't showing in my account.
I messaged a CS Agent one last time, and figured if it's not resolved, I'll just let it go.
Just wondering if anyone else has experienced the same problem?
9 REPLIES 9
tiffk17
This has since been resolved! Just required some persistence 🙂
tiffk17
Hello,
I'm talking about two separate accounts 🙂 both recent activations. One I was able to apply a promo code, and one I was not.
Thank you though!
HI @tiffk17 if your son has the $10 , you are good
you are on the new point system, you won't see that 1 point until your renewal.
_AE_Collector
You say your son received his $10 which tells me he is the new account. If you did the referral you don’t get $10, you get $1 per month. Unless there is a referral promo on that I am unaware of.
tiffk17
I didn't receive a text, but it's showing up in my son's account (I already used the $10 credit when upgrading my son to a better plan haha); and it's showing up in my account that I have successfully used my referral code for one person.
It's my account that's giving me issues with applying referral codes, and I really want it to work because it was your code I gave for my account and you've helped me a lot since I've joined!
hi @tiffk17
Yeah..
for your son, push them.  I did hve one experience, I have to push back and forth and have them to escalate and escalate
but you got the Cha-ching text telling you " you have a friend just joined"?
but don't give up.. they will check and fix it eventually
tiffk17
I'm glad to hear it's not giving you issues for anyone else though!
tiffk17
@hTideGnowit was your code I used haha.
It was applied 6 days ago, and still isn't coming through on my end.
I used my code for my son's phone plan and it worked. Not sure why I seem to be having issues.
HI @tiffk17
no, my friend just used my code and everything went well
are you the one who just joined? yes, the $10 should be there within 3 days, it will be on the My Account, showing up in Available funds.
how about the one who gave you the code, he got the Cha-Ching text?
