12-01-2023 06:20 AM - last edited on 12-01-2023 02:45 PM by computergeek541
I purchased the US Talk, text and data add on. I can text but I cannot call. I keep getting the call failed message immediately.
12-01-2023 09:58 AM
HI @Ruthie64
what phone do you have? iPhone or Android?
Generally, go to Settings, Mobile screen and change Network from Automatic to Manual and wait for T-Mobile to come and select it
12-01-2023 09:55 AM
How do I switch to T-Mobile?
12-01-2023 07:41 AM
Do you know if you have a VoLTE compatible phone? Which model phone do you have?
With the decommissioning of the 3G network in the US, have a VoLTE phone is important to get better calling feature. If you don't have VoLTE phone, then try T mobile 2G network if available
Here is some more info:
https://publicmobile.ca/en/ab/get-help/articles/volte
12-01-2023 06:27 AM
@Ruthie64 , are you connected to T-Mobile or AT&T? Manually connect to T-Mobile & see if it helps? If not try AT&T.
