Add-on trouble
MP11
Bought $15 Cam/US longdistance add-on Sept 18, funds deducted but no minures added, can you help
darlicious
@MP11
Just to be clear there is no Canada/US $15 long distance add on rather there is calling add on that you can use while you are in Canada to call the US. $15/1000 minute calling add on. Then there is a $5/500min add on for Canada wide long distance calling (or local).
.....and always add the funds to your account balance then buy the add on. Confirm and submit.
Triguy
You need to add the add-on to your account.
To purchase Add-Ons using your Self-Serve account, follow these steps:
  1. Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
  2. Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
  3. When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
    • You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
    • If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
  4. Select ‘Confirm my purchase’, and you’re off to the races!
@MP11
can you try to do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
To get the obvious out of the way...you used ( +1 or 1 ) in front of the any area code,
for Example long distance, Add (+1 or 1 ) in front of the any area code,
1416xxxxxxx,
or
+1416xxxxxxx,
both is will going through your call...
Good luck and enjoy the service..
@MP11
Buying an add on is a two step process:
1. Load up funds to available balance
2.  Then purchase add on.
@MP11
sign in to Self-Serve, to review your account, if you found at Available Funds: $ ?
Try To Purchase Add-Ons Using Your Self-Serve Account
  5. after you Add-on you have to do Rebooting your phone
Overview Of Add-Ons visit Here link.
