Add on 300 International Minutes
Yea123
Can I get some clarification?
if I understand correctly, the 300 international minutes does not expire at all. I can use it until it’s finished. Am i right about it?
Yea123
Thanks for the heads up! I was  about to purchase add on.
Phil_Adelphus
@Yea123   It doesn't expire but make sure the country/ies you want to call are on the list for that add-on because not all countries are covered.  Also there are separate add-ons for calling certain specific countries.
Yea123
Thank you so much!
@Yea123  Yes that’s correct it will roll over until all used up
