04-21-2023 03:06 PM
I opened up an account and transferred my phone number from Koodo however my new Public Mobile phone line shows no network connection. How do I get it to work?
04-21-2023 03:27 PM
as advised on your other post, this is likely a sim card provisioning issue, you just need to open ticket to engage PM support:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Activation/td-p/973190
04-21-2023 03:25 PM - edited 04-21-2023 03:25 PM
Reboot phone (turn off/on)
Remove SIM and reinsert it
Try your SIM in another phone to see if it is SIM issue.
Try Other SIM in your phone to see if it is phone issue.
Possible service outage in your area.
04-21-2023 03:24 PM
@yolande1944 Assuming you have tried to reboot the phone and still not connecting to public mobile you may need to reach out to support to have them reprovision the SIM card for you
Watch for reply top of page to the
Right ( envelope image )
04-21-2023 03:19 PM
My phone does not work it shows me the following message: no network connection
04-21-2023 03:10 PM
@yolande1944 if your new PM sim card does not even connect, it is a problem with sim card provisioning. No worry, it is an easy fix for PM support, you just need to open ticket to engage them
1. Please open ticket via Chatbot (requires access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
04-21-2023 03:08 PM
Log in to your account and verify is account is Active and confirm number is ported (if you followed porting instructions to the letter).
Use COMPUTER not phone to do that...
