Activation not working
SandyK1233
Almost 24 hours since activating but no service yet. Porting from Koodo
Joe_Tools60
Hi. Try reseating the phone card. Take it out and then put it back in. Make sure it is the right side up . Then reboot your phone. This should work. Wait 20 mins.
HI @SandyK1233
you  ever try the sim card in another phone?
if you re using esim , check Sim Manager and see if the esim is there and if it is enabled or "Turn on this line"
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
@SandyK1233
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
