Activated my card how long to work?
VanessaLeitao
I just activated my SIM card.
"Congratulations Vanessa!
Your SIM card is now active on Canada’s largest Mobile Network", so after I went and inserted my card on my unlocked phone and it still says No SIM.
How long does it take to start working?
79 REPLIES 79
RabbitEffect
Thanks to everyone in this thread that has helped out. I just joined and I really appreciate the support everyone provides!
@claudedunn @VanessaLeitao
Whoop! Whoop! Everyone's on the pm train! Whoop! Whoop!
claudedunn
Thanks, nice community here, lots of help
Cool.. we have 2 happy customers now.
Also, with the amount of postings and bravos you have so far, probably you will have $1 or $2 Community Rewards for this month.  Not a lot, but a still a "compensation" you deserve.
Enjoy PM.
VanessaLeitao
Yes, same. They fixed it. Everything is working, and I'm happy.
Thank you all for the help 😉
@claudedunn  happy that you are happy.. enjoy
claudedunn
they solved everything, im very happy now, thank you, it was worth the wait
@VanessaLeitao @claudedunn
how the activation ?  I message the CS Agent team earlier and today, finally, I was told they have already reached out to you.  Hope your issue is finally resolved or will be resolve soon
@VanessaLeitao
If the SIM card is a dud just purchase a new SIM card and save the receipt. Submit the receipt to the CSA and they will credit your account the purchase price. Are you still able to purchase a card today?
You may also be able to purchase SIM cards at 7/11, Shell, Husky and maybe Mobil stations and the TMS and/or Loblaws/RCSS equivalent ( Provigo?)in Quebec. Call around first with the new fongo app you just downloaded.....😃!
Do you now have access to your self serve account?
VanessaLeitao
True, but the place where I get the SIM card is right next to the store I will test again with them just to make sure, and then if I'm right, I will then ask for the reimburse.
Thank you.
 @VanessaLeitao : Then you don't need further testing at a store. You've tested the presumably activated SIM in another phone and it didn't work. You've tested another SIM in your phone and it works.
I would report these findings back to the CSA and maybe they'll just say to get another SIM and they should reimburse you for the cost.
VanessaLeitao
Yes I've done that. My device is fine.
As I said it before, As soon as I can I will go to a store and test it.
Thank you all for your help.
@VanessaLeitao wrote:
Yea, I did try on a friend. and didn't work too.
@VanessaLeitao
ok then take your friend SIM card put it in your device is will working ? test your device !!
claudedunn
Yes, Public is the self service version of telus and ownm by it, that why i choose them, one of the best network
@VanessaLeitao
public mobile not have any store, you can go to any store in your area to test it and told them any store the can help you for test the SIM card all device in canada is it unlocked....
VanessaLeitao
claudedunn
yes, actually
 @VanessaLeitao : You don't have a friend or relative with a phone nearby to try your SIM in?
VanessaLeitao
Oh I thought I had to really go to a PM store. So I can just go to a Telus store right?
@VanessaLeitao
go to any store the have test device the will can help me to test it is not about public mobile, go to any store anywhere and if find Telus store near you, the will test it any SIM card to see where the issue from SIM card or your device.....
claudedunn
Thank you, glad your all ok
VanessaLeitao
Apparently seems like a SIM card problem. Will need to go to a store so they can test on another device. But I'm afraid Montreal doesn't have any physical store of Public
Yes they just replied to me.
We still trying to fix it.
be patient with them and make sure you are ask them what you need to do you know and i happy for you will getting service to you will enjoy it
Good Luck
claudedunn
great, i hope im next !
VanessaLeitao
@VanessaLeitao
I take it you finally received a reply from customer support.....woohoo!😃 I hope?🤔
I will send you a private message in a little bit.
@claudedunn
Things are looking up!🤞
VanessaLeitao
New one.
@VanessaLeitao
Did you port your phone number in or choose a new one?
@VanessaLeitao
Do you have access to WiFi? ( Assuming yes since you are here.) Download the fongo app so you have a working phone number on WiFi. Once you have service the fongo app will also work on mobile data (0.5mb=1min of calling). It is also an effective work around for international roaming that pm does not offer (outside of the US) on WiFi or with a local or global sim by call forwarding your pm number to your fongo number before you leave Canada. It will also work to maintain calling if you are going to an area not serviced by the 3G network that pm uses for your calling service.
VanessaLeitao
No because without this new card my phone doesn't work. I moved to Montreal 3 days ago. Bought this card to have a phone number, and because of this situation I don't have a phone working at the moment.
