Accounts
noah12
Thanks for all the replies on my other post. I know now i use the app to setup every phone, I have 3 phones i want setup. Can I log in with the same credentials on each phone so basically i will have one account with 3 lines? Is the 5G truly 5g as if it would be with Telus?
9 REPLIES 9
noah12
Thanks, I believe all my questions have been answered
HI @noah12
don't think anyone answered this yet
Yes, PM uses Telus network so the 5G is the same, on the same 5G network
PM has a 250Mbps speed limit on the 5G plans, which is the same as Telus regular 5G plan.  However, Telus also offer super 5G plan (5G+) and it can reach up to 1Gbps (1000Mbps)
noah12
Thanks for all the replies guys, you are all great
Chrissyrioux12
One email per account and one account per phone can’t have the same
noah12
Thank your for the info
noah12
Thanks luckily, I have 3 separate emails. Thanks for all the info
snowisfalling
No you need one account for 1 sim card and 1 different email for each. But you can pay with the same credit card for the 3. I guess that is a limitation with Public mobile.
Yummy
No.
Each account has to be independent. You need 3 separate, unique emails. You will get 3 phone numbers. To maintain each account you would need to log in to each account separately.
Password could be the same (not recommended).
Yu can pay for all 3 accounts with the Same credit card.
