8gb 4G plan for $45
dancybak
I paid for this on July 20/22, but my plan still shows I’m on my old plan and says I’ve used all my data which is simply not accurate. Can someone help clarify this please?
JL9
This seems to be an issue for many making a change recently. You can connect with a CSA to get it sorted out so they could manually change it for you if it is still not showing in your self serve. Keep us updated on how it gets resolved.
HI @dancybak
Use Incognito mode to try login again to make sure the details showing are up to date
If it still show you are on the old plan, check Payment History page and it will tell you if they charged you the new plan charge on July 20 (if the transaction details are unclear, post screenshot and we can try to help)
if they charged you new plan but still offering old one, open ticket with CS agent
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
Timer
@dancybak
Did you change your plan immediately or on your renewal date?
There are 2 options for your to change your plan.
BTW, it is $55 for 8gb or $45 for 6gb at 4G.
Timer
@dancybak
tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
and new plan is take up to 48hr to post in your account.
