48 hours after subscribing and still no incoming calls!!!!!!!!
DaddyLife11
Does any one know if there is ANY way of actually getting help with this company ?????? I activated my service 2 days ago and cannot still access my services no data, cannot make calls !
9 REPLIES 9
@Handy1
9:00am to 10:00pm EST.
DaddyLife11
appreciate your help
@DaddyLife11 if you cannot even make outgoing calls, and no data, it is a sim provisioning issue. Easy fix for PM but you need to message them to engage them. Look like you did already. They work till 10 PM EST, but weekend support could be slower.  Please message them once more and hope they can get it sorted out tonight
@DaddyLife11 reboot the phone once more and check
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
@DaddyLife11  8amEST to 10PM EST I believe
DaddyLife11
Do you happen to know the support hours ?
@DaddyLife11  Sent to your community inbox or get to it thru this link
adding @DaddyLife11  if you have already spoke to agent . Have they asked you to reboot the phone or reset network settings . If not you can also give that a try also
DaddyLife11
hello Handy1,
I did port a number but spoke with a CS via msg who confirmed it would be fine after 2.5 hours ........ yesterday. thank you so much i'll keep an eye out for your msg
@DaddyLife11  Did you port a number into PM and miss the confirmation text to reply a YES . If so there a number for live support to help fix . Will send private message as we not allowed to post it here
Adding if your needs support please @DaddyLife11
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
