07-14-2018 01:33 AM - edited 01-04-2022 06:27 PM
Hi all,
I know you wont notice a big difference if you are doing the usual like browsing, emails and social media.....and I know you might see an issue with streaming/downloading large files.
BUT is there anyone out there who plays poker on their mobile device? If so, did they notice a significant difference between playing poker on their mobile phone with LTE and 3G.
Or is it too unreliable for doing so?
Thanks.
07-15-2018 03:01 AM
There is no issue with poker, unless its all video streaming poker games.
07-14-2018 09:38 AM
Great, thanks guys. Gives me a little peace of mind on that front.
07-14-2018 08:06 AM
@JL9 wrote:Hi all,
Thanks.
I play it, and it's fine. I don't see any difference from when I was on Telus LTE
GC
07-14-2018 04:59 AM
If you are close enough to a tower, reliability, ether in 3G or LTE, will not be a problem. Programs like that do not use that much bandwidth, and you will still get the LTE latency advantages, even when throttled to 3G speeds. I am confident, you will do just fine with that app and any of Public Mobile's data plans.
07-14-2018 03:12 AM
