08-18-2021 08:52 PM - edited 01-06-2022 03:11 AM
Hi everyone,
This seems to have happened to me for 2 months now. My 3G plan is used up within a few days of plan reset. I reset my iPhone data statistics to demonstrate that only 1G was used up. Something seems to be off with my data usage, can someone help?
Picture evidence attached of the discrepancy.
08-19-2021 01:50 PM
@jingloh Your screenshots show you last did a counter reset on Aug 12. Does that align with your last actual plan renewal date according to self-serve?
I see you have marked a post suggesting contacting the CS Agents as the solution, so I am curious what the actual resolution was.
08-18-2021 10:12 PM - edited 08-18-2021 10:13 PM
As others have alluded, are you sure your account reset date is aligned with your phone's counter?
Plans renew every 30 days, not every month.
What is the data usage delta between your phone and the online account status page?
08-18-2021 09:52 PM
@jingloh since you are on iOS, maybe you can try My Data Manager. It helps to track data used in 30 days cycle as PM is on that.
08-18-2021 09:05 PM - edited 08-18-2021 09:07 PM
@jingloh wrote:Hi everyone,
The accurate use of Data would be listed on your Overview section of your Self Serve account.
IF you have not created a Self Serve account you can do that here: https://selfserve.publicmobile.ca/self-registration/
It looks like you are showing your device's usage.
Note plans are 30 day cycles at Public Mobile NOT monthly.
So see when your next payment is due and that is when your Data usage will start next cycle.
EDIT:
Install an app to track your ‘live’ usage so you can keep track by 30 day cycles.
If you are android, try this one:
Data Witness app: https://play.google.com/store/apps/detailsid=com.iwik.datawitnesspm&hl=en_CA&gl=US
I use this one myself and it gives me what I need from it.
You could also check out Data counter widget: https://play.google.com/store/apps/details?id=com.roysolberg.android.datacounter&hl=en_CA&gl=US
If you are an Apple user, I am sure there is a 30-day app that is available as well.
Managing Your Data Usage:
https://www.publicmobile.ca/en/bc/get-help/articles/managing-your-data-usage
08-18-2021 08:54 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
Good Luck
