$34 unlimited data plan is back, or wait, quebec only?
OnlPM
As I have 2 family members waiting for 'my plan'($34 50gb fast, unlimited data @ up to 512kbps after), I've been checking the plans waiting for it to return.  I guess it detected me as being in quebec initially; before I selected Nova Scotia... Still it shows me this plan:
https://subscribe.publicmobile.ca/en/ns/activation/plans/60GB-5Gspeed15
In the "Offer Details" at the very bottom it says for Quebec only...  It did/does show it to me after selecting Nova Scotia.
Is publicmobile gonna let me get this for NS family members? Do they enforce it or might it be a throwback from when I was detected as quebec.
10 REPLIES 10
@OnlPM   It's offered in every province that I looked at.  Remember the "offer details" don't all apply to any given plan.  You have to match up the symbols/numbers with what's on the plan.  The Quebec only note has a + but there is no + on the plan.
OnlPM
Offer Details at the bottom still says "⁺This plan is for Quebec residents only and intended for use in Quebec." for me... hmm!
Charisma
I live in Nova Scotia and I just switched for when my next billing cycle starts. It confirms what I’ll be getting when I switch over and says unlimited data. I’d get your family to do it before it goes away 🙂
Phil_Adelphus
@OnlPM   It's back, see (but be careful to pick the right $34 plan now that there are two):
https://productioncommunity.publicmobile.ca/t5/Get-Support/34-unlimited-data-plan-now-available/td-p...
OnlPM
I am in NS and got the unlimited data plan last month but they ended it..(they day after family said to get it for them). So I have 2 family members in NS now 'wanting' the plan I have, so just trying to get it for them.. Guess I'll keep them waiting.. no unlimited data no sale.
Thanks for confirming suspicions.  drag.
@OnlPM wrote:
The plan your referring to is "not back" it is a new one that is Canada-US with(the important part) NO unlimited data after 50gb.
@OnlPM
yes, the current $34 plan is NOT the same
the Canada only $34 plan is not currently available.  Sound like you need the 512Kbps more, but technically, the Canada-US one is a better deal.  But sorry, the Canada only $34 is NOT back at the moment
OnlPM
The plan your referring to is "not back" it is a new one that is Canada-US with(the important part) NO unlimited data after 50gb.   Where as last month I signed up for the one without "US" service but had the '2'  512kbps unlimited after you used up your highspeed... (both were available at that time)
Unless of course they are obscuring things and the Canada-US does have unlimited data after 50gb but not mentioning it with the '2' details citation.
hmm
@OnlPM
the current $34 plan is a Canada-US plan and does not include unlimited 512kbps data
and if you do not have a credit card that linked to a Quebec address, you won't be able to activate a Quebec only plan
and again, if you are in NS, this is the $34 plan for you:
https://subscribe.publicmobile.ca/en/ns/activation/plans/50GB-5Gspeed17
OnlPM
They are not existing customers, they want to be if they can get a ~$34 50gb-512kbps unlimited data after using up the "50gb" highspeed.  512kbps should be enough for ~240/480p video on youtube unlike their existing luckymobile that has 128kbps unlimited.
Unless I hear otherwise I guess they can just try signing up; however they are likely to charge for the first month to get mailed the simcard and maybe be stopped on activation if not quebec address..
Yes, they and I can easily use 50gb; I 'work' to try to stay under that but there's a lot of bloat data out there and I use my connection as hotspot and on the go.
@OnlPM
the $34-50GB Canada-US plan is back for everyone
The "Offer Details" you see is a one single template cover for all plans, the words about Quebec only is about those Quebec only plan, which the $34 one is NOT, it is a plan for everyone
Add: to clarify, if you are in NS, your plan should be this one:
and NOT https://subscribe.publicmobile.ca/en/ns/activation/plans/60GB-5Gspeed15
To minimize confusion, only plans showing here are for NS Subscribers:
https://www.publicmobile.ca/en/ns/plans?network=ALL
