$34 plan for 20GB
darleneP
I wanted to switch to this plan but for some reason it doesn't appear to me. Two of my siblings have it but for some reason, I can't see it. Isn't it available for everyone for the Black Friday deals?
Jakss8w
Restarting the web with a different browser worked for me.
I feel it is a competitive plan with great pricing if a new device is not required.
Abheer
No problem, enjoy the great deal!
darleneP
I have it now! Thank you everyone
@darleneP
If you are using the PM app, click on the “+” in circle then Subscription & Add-on>Change Subscription>check if it is under ALL plans.
Abheer
Hi @darleneP
If you're an existing subscriber, it should show you when you go to "Subscriptions and Add-Ons" then click on "Change Subscription". If the 5G plan does not show up there, contact a customer support agent using the following link and let them know you want this plan.
Monitor the envelope icon on the top right because that is where you will receive the response.
DennyCrane
Try clearing your cache or using an Incognito/private browsing window. It's available to everyone.
