300 International minutes add-on
3100fries
If I purchase the 300 international minutes add-on package will it work in Mexico and do I still have to purchase a roaming package.
CountyDownIeUk
You are SOL on both. You will need to use voip with wifi or FaceTime with wifi or find a SIM plan in Mexico.
@3100fries
You will need to purchase a local SIM or use TextNow or WhatsApp through wifi.
International minute only works if you call from Canada not from Mexico.
@3100fries  No, it won't work
LD minutes are to use to call FROM Canada
and PM does not have roaming service in Mexico.  so, there is no way to use the service in Mexico.  Please use local prepaid service
Quigley
@3100fries
Sorry there's no roaming in Mexico and getting that add on won't work in Mexico either.
